MR2, 1987
MR2, 1987
Post by webmaster » 08 Aug 2005 14:56
På engelsk, klippet fra websiden min...:-)
My MR was made in Japan in December '86, and was delivered to the port of Drammen, Norway January 18, 1987. It's first owner purchased it March 24th. After that, two more had the pleasure of owning it, until I bought it December 23, 1994 (nice X-mas present for myself...:-D).
Modifications done (in the order they were done):
  • - Blaupunkt München RDS radio/CD-player, Magnum bass-tubes behind the seats (28/01/95)
    - Total repaint (23/04/95)
    - Momo Ferrari Engineering 7"x15" wheels, offset 38 mm (18/07/95)
    - Yokohama A510 205/50/15 tyres (18/07/95)
    - Momo Superanatomico stick (09/08/95)
    - Momo Champion steering wheel (18/10/95)
    - Adjustable air/fuel mixture via knob on dash (removed when new chip was installed)
    - Yellow Koni adjustable shocks all round (28/03/96)
    - Cerwin Vega! AI 42 speakers in dash (04/05/96)
    - Replaced left and right rear fenders due to unbeatable rust in the wheel-wells (expensive as you'd never believe - $4100/£2500 parts, paint & labor) (11/07/96)
    - Momo carbon fibre pedal set (16/07/96)
    - Janspeed exhaust - perhaps my best investment yet (15/08/96)
    - Tokico springs all round, lowered 30 mm (08/03/97)
    - HKS Super PowerFlow induction kit (15/03/97)
    - C's short stroke shift (15/03/97)
    - VDO oil temperature and oil pressure gauges (30/03/97)
    - New clutch; Centerforce Dual Friction (01/04/97)
    - New flywheel; HKS Ultralight, only 4.8 kg compared to the originals' 9 kg (01/04/97)
    - Complete suspension adjustment, more negative camber! (09/07/97)
    - New alarm (18/07/97)
    - Chiptuning by Simco here in Norway. +13 hp on the dyno (29/07/97)
    - Red Line gearoil (08/08/97)
    - Clear corner lights, Toyota part no.'s 81521-03011 and 81511-03011 (11/10/97)
    - Removed the radio and the Magnum bass-tubes - wasn't ever being used anyway, and the weight went down...:-) Kept the speakers in the dash for that occasional radio use
    - Tilton Brake proportioning valve - yihaa! Finally proper braking, with close to 50/50 front/rear ratio. Bought it from Demon Tweeks (10/07/98)
    - Changed to coolant from Comma, supposed to lower the temperature compared to a normal coolant, and that's got to be for the best...:-) (12/07/98 )
    - Mocal Aeroquip TFE steel braided brake lines (17/08/98 )
    - Removed the (butt ugly) sideskirts, and put original MR2 mudflaps on instead - what a relief! (15/04/99)
    - TAR·OX slotted front brakediscs - made one hell of a difference! I got my 20-groove discs from Demon Tweeks. Swapped the rear discs for new original Toyota discs at the same time, as well as new studs all 'round (14/05/99)
    - Wired the driving lights properly in time for the bi-annual government control of the car, thanks to Inge for that! (20/06/99)
    - Bosch Super-4 sparkplugs - thought I'd try them for a change, but I guess I'll go back to Toyota originals next time (no difference) (15/07/99)
    - FSE Power Boost Valve to be able to adjust the fuel pressure (20/01/00)
    - Went for a loooong trip around Europe (4000+ kms) - not a mod, I know, but still...:-D Had the old thing at 215 km/h on a slight uphill on the German Autobahn - steady as a rock! The moulding above the windshield came loose, and made a horrible, vibrating sound at 190 km/h. (22/06-07/07/00)
    - New tyres, Bridgestone Potenza S-02 - 205/50/15 (10/08/00)
    - Fully adjustable swaybars by Suspension Techniques front (installed) and rear (pending) (15/08/00)
    - Replaced windshield with mouldings (see why above) and removed some rust around it (08/09/00)
    - Finally installed the rear Suspension Techniques swaybar - going racing sunday 10th... (09/09/00)
    - After the trackday on the 10th, I heard some disturbing noises from the back of the car...it took 5 months before I had the time to investigate (not a problem, the car was in storage for winter). What I found was that the bolts for the rear swaybar were too long, causing them to scrape the wheelwells...ouch... After using a hacksaw on them, this was no longer a problem (15/02/01)
    - Installed Momo Cup drivers seat (after fabricating brackets...), lost 10 kg on the original seat - a whole trackday showed it was worth it, I range this among the best improvements I've done to my car! I've never felt so in control of my car. Thanks to Tommy Guttman and Dave Aucott for the inspiration (21/06/01)
    - After having a 2 Kg Gloria fire extinguisher rolling around in the front luggage compartment for a year, I came round to mounting it inside the car, fits nicely in front of the passenger seat (21/06/01)
    - EBC Green Stuff front brake pads - kevlar high friction compund, effective up to 550 deg. Celcius. Supposedly virtually dustfree. I wonder if they work any better than stock? I'll know when the upcoming trip to Nurburgrings Nordschleife is over...:-) UPDATE: The dust was no less than the standard Toyota pads...
    - New ignition leads, Magnecor 8mm from Fensport (07/01/02)
    - Dual A-pillar gaugepod from Lo-Tek (11/04/02)
    - Clear side markers/turn signals from Autoart via Halfords in th UK (thanks, Chris!), part number TY-305 (30/04/2002)
    - Finally found some time to replace both rear calipers, which had seized. -Cost about $400 for two new replacement calipers...ouch (09/08/2002)
    - Changed to EBC brake fluid (307 deg. Celcius boilingpoint) (09/08/2002)
    - Changed the HKS airfilter element in my Super Powerflow - about time too...for fun I ordered an orange element this time...;-) (09/04/2003)
    - Changed the spark plugs (orig. Toyota) and the oil, as usual, Castrol RS 10/60 (09/04/2003)
    - Installed a dual camerasystem for recording my laps at Nurburgrings Nordschleife this summer. Two bulletcams, one at the front, one at the rear, and an ordinary videocamera to tape it all inside. I might include a third bulletcam to film the suspension working (09/04/2003)
    - Made a mount for an Ipaq (for GPS-mapping) and a Palm (for tracking laps) (09/04/2003)
    - EBC Red stuff brake pads replaced the Green stuff (17/04/2003)
    - Adjusted the Momo seat lower and closer to the steering wheel. I'm now literally sitting on the floor, and in correct distance to the wheel. Only 1 week till Nurburgrings Nordschleife... (17/04/2003)
    - New lap record for the MR2 on the Nürburgring: 9:17 BTG! (02/05/2003)
    The EBC Red Stuff pads were totally finished after 12 laps on the Nürburgring - had to change back to the OEM Toyota pads that I was forunate enough to have with me... No more Red Stuff for me! (04/05/2003)
    - Set a new personal max speed on the Autobahn in Germany - 207 km/h according to the GPS. 230 km/h according to the speedometer...:-D (05/05/2003)
    - Changed the oil and oil filter, as usual, Castrol RS 10/60 (13/07/2003)
    - MTEC SuperWhite bulbs for the headlights installed (13/07/2003)
    - Bought 2 sets of Ferodo brakepads from Demon Tweeks on eBay, not installed yet (26/08/2003)
    - Went to Arctic Circle Raceway (2000 km!) - drove some 200 km on the track and came home without incidents! Almost hit a reindeer, though...:-) Tyres are now shot, have to wait for spring to buy some new... (01/09/2003)
    - Measured camber (25/09/2003):Left front: -1.9
    Right front: -1.8
    Left rear: -1.8
    Right rear: -2.4
    - New tyres, Yokohama AVS Sport 205/50/15 (22/04/2004)
    - I've been restoring the original teardrop-rims, the goal is to put Yokohama A-032 racetyres on them for track use. The rims need one more layer of paint, but next week I'll put the 32's on them, and I'm really looking forward to testing them on the track, late in May, that is (30/04/2004)
    - R-tyres mounted on restored rims! (05/05/2004)
    - More on the R-tyres: Got some hints that I might be running way too high pressure in them, so I filled them up with 1.6 (front) and 1.7 (rear) bar, tyres cold. After some laps I measured the pressure again, and it was up to 2.4/2.5 bar! So while it was still too much, the difference was breathtaking! Note that it was 30+ (Celsius) the day I tested, the pressure will vary with the temperature in the air
    - Changed the oil and oil filter, as usual, Castrol RS 10/60 (13/05/2004)
    - Replaced the 'triangles' by the mirrors, cheap and much, much better than the old, glued ones (03/06/2004)
    - Changed the coolant, again from Comma. It's been 6 years since I changed it, and would you believe the old coolant was as good as new? If someone had looked at the old next to the new, that someone would be hard pressed to point out which was which. Also changed the draining plug on the top of the engine (29/07/2004)
    - Out of winter storage. Changed the oil, oil filter, spark plugs, rotor and distr. cap (14/04/2005)
    - Another trackday at Rudskogen - fun with no incidents! (05/07/2005)
Modifications pending:
  • - Ferodo brakepads, front
    - Cusco rear strut tower brace - I'm having a hard time finding it in Europe.
    - New throttle system in the engineroom. Relocate throttlecable to the side of the engine, revealing the nice camcovers properly. Parts purchased, not installed.
    - A complete set of polyurethane bushings from Fensport
    - Thermo-Tec exhaust wrap for heat insulation. I'm going to use this from the downpipe all the way to silencer on the Janspeed, and if there's any left, I'll use that on the manifold. Purchased, not installed
    - Pro-Bolt Cam/Rocker cover kit. Purchased, not installed
    - More tuning? Might include porting, cams+++
Post by Shadow_iX » 08 Aug 2005 17:23
MR2 er bare helt enkelt en genial bil da. :)
Post by webmaster » 08 Aug 2005 19:09
Jepp, og nå er de latterlig billige, dessverre er de fleste veldig rustskadet...men skal man bare ha en morsom bil til banekjøring er det billig moro!
Post by Shadow_iX » 09 Aug 2005 07:35
Yepp.. En kompis av meg har lyst til å kjøpe en rusten MR2 mk1'er og ha som prosjekt/banebil - håper han får det til etterhevrt, morro å hjelpe til med å bygge bil.
Post by webmaster » 09 Aug 2005 11:55
Noe slikt Inge og jeg har fabulert om, men tiden strekker vel ikke til...:-(
Post by Shadow_iX » 09 Aug 2005 12:40
Uff, ja... Denna tida som flyr for fort ja, er no herk det.. hehe
Post by webmaster » 09 Aug 2005 14:48
Jaja...driver og titter på mulighetene til å få tak i øvre stabstag bak igjen, hadde en runde på det for 1 år siden men det kom ikke noe ut av det. Det er ikke tilfeldigvis noen som har lyst til å sveise sammen et slikt stag for meg? :-D
Andre
Post by Andre » 09 Aug 2005 15:22
virker til å være veldig bra den mk1 der ja.... skal vi bytte :lol:
kjører mr2mk1 86mod
Post by webmaster » 09 Aug 2005 15:29
Gjerne det...mot et heftig mellomlegg...:-)
Andre
Post by Andre » 09 Aug 2005 15:53
nei den bilen må du søren meg ikke selge ,kommer jo bare til å stige i verdi den om du fortsetter å holde den så bra ... mk2 er det jo godt inflasjon i mens pene mk1 bare blir et mer og mer sjeldent syn...
kjører mr2mk1 86mod
Post by webmaster » 10 Aug 2005 09:34
Nei, go'bilen blir nok ikke solgt. :twisted:
Post by henning » 10 Aug 2005 11:24
webmaster wrote:Nei, go'bilen blir nok ikke solgt. :twisted:
Bare 8 år igjen til veteran :lol:
Post by Shadow_iX » 10 Aug 2005 11:43
8år ja, det bør vel gå passere fort om man har det morro nok.. hehe
Anders Gullstein
Post by Anders Gullstein » 22 Aug 2005 11:06
Steike som tia flyr, husker den tia de var ny jeg. Nå er min på go vei til å bli 20 :) . Blir ikke noe salg i mitt tilfelle heller, har vært i min eie i snart 6 år nå.
Livet er for kort for kjedelige biler!
86 Toyota MR2 til å ta alle kronglette omveier.....
04 Subaru Impreza 2,0 GX til daglig og moro på vinter
06 Toyota Avensis 1,6 stv til fruen
inge
Post by inge » 22 Aug 2005 19:11
ja fytti rakkar'n som tida går. Jeg husker enda godt flyturen til Trondheim, da jeg skulle hente min. Den ble registrert på 25år dagen min... 17,5 år siden gitt.....
'87 Toyota MR2
'06 Ariel Atom2
'09 Ferrari 430 Scuderia
'14 BMW i3 (pendlerbil)
